Brake lights are stuck on - Help!
I have recently bought a 2005 a4 tdi estate b6 shape. Im having major issues with the brake lights being permanently stuck on. I've tried replacing the brake light switch (twice both with new genuine switches and following the correct fitting instructions, just incase one was faulty out of the box!) and also the brake light bulbs.
When the ignition is off, there is no problem with the brake lights they all work as they should, the problem arises as soon as the ignition is switched on, the lights come on and stay on.
Occastionally the high level brake light works normally as it should but the 2 lower side brake lights are always jammed on!
If anyone has any ideas I would be grateful
![Confused](https://www.audiworld.com/forums/images/smilies/confused.gif)
I pulled the rear lights out and looked at the wiring and it is all original.
One thing I have found today is that there is a permanent live feed from the central control module to the red and white wire once the ignition is switched on. If I unplug the multiplug and live this wire from my test probe it switches on the brake lights.
I tried another module in it with the same part number but no difference whatsoever. I phoned the dealer to check if it is the correct module for the car and sure enough it is.
I thought I was getting somewhere but no, now back to the drawing board!
Seems like the brake light circuit isn't closing. Meaning maybe there's a wire some where that's constantly supplying the brake lights power when they should be off.
Might have to back track through the wiring harness to see if that's valid.
It's about the only logical explanation - definitely odd two switches would not change the out come.
Jason
Jason
Brake lights really on or is it the DRL mode in operation? On the 2005 Canadian models, the front fogs function as the DRL and the front parking lights and rear tail lights are always on.
If anyone has any ideas I would be grateful![Confused](https://www.audiworld.com/forums/images/smilies/confused.gif)
solve yours ?
N'Syncro
33
02-16-2020 03:12 PM
jjcuff1
A6 (C7 Platform) Discussion
09-08-2015 12:02 AM
DannyG123US
09-07-2015 05:53 PM
stormchaser1967
09-02-2015 09:26 AM
