Brake Pad Sensor?
ECS sells one. Might be the neatest solution when I get my BBK. Here's their description:
ECS Brake Wear Sensor Loop-Square Round Connector
This ECS brake wire loop eliminates your brake pad indicator without cutting &/or splicing your wires
This ECS wiring harness plugs right into the car harness & eliminates the brake pad sensor light by proving a continuous loop. Basically this is the brake pad harness that is on a set of brake pads minus the pads.
If you have a brake upgrade but your don't check your pads once in a while (or change them when you track) then you're probably just posing and deserve to wear them without knowing.
S4intheOC
09-08-2015 12:12 AM
ECS Tuning-Audi
09-02-2015 11:39 AM
