Can I go from OEM xenon to S4 bixenon ecodes by swapping bulbs and projectors?
Old 04-07-2005, 06:50 AM
PuRe's Avatar
Default Can I go from OEM xenon to S4 bixenon ecodes by swapping bulbs and projectors?
Or is the process more complicated than pulling the bulb and projector? I usually ignore lighting questions...but I'm getting ready to make the leap to ecodes and figured I'd do bixenon ecodes in the process.
Old 04-07-2005, 07:02 AM
Eddie Man's Avatar
Yep...Steve "USP Quattro" & DD have done it, but you'll need new/different high beam bulbs.
Old 04-07-2005, 07:08 AM
PuRe's Avatar
Will I need to make any wiring changes (other than swapping the bulbs, ballasts, projectors)?
Old 04-07-2005, 07:31 AM
Eddie Man's Avatar
Default Nope...You may need to do some fynagagling w/some stuff behind the unit...BiXenon rear...
compartment is larger than standard ecodes or xenons.
Old 04-07-2005, 07:38 AM
cyberpmg's Avatar
Default I did it last weekend....
I was able to use my Xenon bulbs and ballasts. I was also able to use my Halogen high beam bulbs. I could not use my turn signal bulbs (different connector). You'll need 7507 bulbs for those (less than $4 for a two pack if you don't go with silvers).
No wiring changes - all plug and play.
The only thing you'll have to do is to move two wire connectors that are attached to a metal holder behind the driver's side housing. They unclip/slide out from the holder to allow the ecode housing to be installed. You can then reattach one of the wire connectors to the top position in the holder. The other one can snugly fit around the outside of the holder away from the ecode housing.
Old 04-07-2005, 08:07 AM
PuRe's Avatar
Default Awesome...thanks for the info! (m)
btw, I know that the plug and play S4 bixenon ecodes go for ~$600-$900. What's a decent price for just the S4 bixenon ecode housings?
Old 04-07-2005, 08:38 AM
akula-ssh's Avatar
Default Just a quick note: you won't be swapping the projectors: that's the piece that makes it bixenon
Just a matter of swapping bulbs, as other have said otherwise.
Old 04-07-2005, 08:40 AM
akula-ssh's Avatar
Default Unless prices have dropped dramatically, it costs $600 or more for just the housings
Without ballast and bulbs (which I'm guessing is what you meant by "plug and play").
Old 04-07-2005, 08:48 AM
cyberpmg's Avatar
Correct. You can get the S4 Bi-Xenon housings for $600 at ECS Tuning.
Old 04-07-2005, 09:00 AM
mitchelm's Avatar
Default I did it too, and didn't need new high beam bulbs ...
In fact, one of the housings came with a highbeam bulb installed, and the other highbeam bulb i took from my OEM xenon setup. Other than that, its plug and play, but a PITA to make the passenger side one fit with the wiring thats there, its just not long enough. I managed to pull on it some as i guess there is some slack on it, but its certainly tight.
Quick Reply: Can I go from OEM xenon to S4 bixenon ecodes by swapping bulbs and projectors?
