Can rear shock dust covers be changed / replaced without removing the shock ?
My dust covers on my rear Bilstein shocks rub on the shock making LOUD rubbing noises ESPECIALLY with a rear passenger..seems there is less clearance between the shock body and the dust cover/sleeve than when new.
Former Vendor
You can technically unbolt the top 2 bolts then compress the shock and unbolt the 3rd bushing nut while still on the car.
This is not an easy task since the Bilstein's are a high pressure shock, and they'll resist you compressing them.
It's much easier to just unbolt the shock from the car.
The probably you're hearing is a common one, something we ran into years ago. Sometimes a little grease on the inside of the boot fixes it.
besides, is it lowered? If so, the noise is likely the suspension bushings and not the shock boot - you shouldn't be able to hear that at all.
of the car ? Do I access the bolts on the upper part of thw wheel well from inside the passenger compartment ?
Former Vendor
Removing the rear shock is very easy. Just 3 bolts, 2 up top and 1 on the bottom.
Slightly peeling the wheel liner back helps to access the top bolts. It's just a couple screws to peel the liner back.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
