Car filled with water!!!!! AGAIN!!!!!!!! Help
I parked car on incline yesterday morning. And after day of rain my passenger side footwell and rear passenger footwell had water in it!!! I assume it is the drain plug behind the battery that is causing this. Does anyone have other suggestions, also is there a write up on what to do to clean this. Also my car had a lot of trouble starting this morning and it looked like the battery reset or something. Any advice is appreciated
I had that problem on the driver side, usually started in the back and overflowed to the front. It seriously drove me nuts with my '96 A4. I tried clearing the plenum drain under the battery, made sure I kept the engine clear of leaves, etc. but the problem kept up. I wasn't able to check the sunroof drain though but had no stains in the headline so don't know it that was it. Be sure to check it too. May be much more difficult however.
check the drain under the battery and remove the plastic piece in there to avoid same situation in the future
hope the hard start is not water in the ecm box unit as it happens with high levels of water and damages the relays there
f29pc
04-19-2022 10:33 AM
f29pc
10-18-2010 12:11 PM
NoFHoes
03-18-2002 12:03 PM
