Car shaking A4 2002 3 liters
I just want to know if it's normal that my car shake when you drive at 140 Kms/hr and you put suddenly the brake?
The car shake a little bit.(Is it a disk problem?)
Let me know if someone try it. I have 17 inches 5 spokes wheels and brand new conti contact two at 32 PSI.
JYVES
JYVES
The ABS was'nt active when I only push the brake at this high speed. None of the wheels stop to turned. The ABS begin to worked when one wheel has the tendency to stop. I did'nt suspect the ABS system. I did'nt suspect also the aligment of the wheels because the car stay stable(straight line).
Let me know what you think!
JYVES
JYVES
...balance harmonic that only show up at higher speed. You might want to try an on car wheel balance for both the fronts. I had the same situation in a Honda. Rebuilt the brakes, cleaned the guide pins and replaced the keeper springs to reduce binding, and went back to stock pads (are you using race pads?). Got rid of the last shimmy by having the fronts balanced while attached to the car.
malinmip
12-23-2009 07:11 AM
Det. Mickylaren
14
11-22-2004 11:47 AM
jec6
05-29-2002 03:27 AM
Greg "S" (not Slater)
08-19-1999 08:20 AM
