Changed my oil for the first time. Some questions.....
I don't why I've been so nervous about doing it. It was about as easy as it gets. The drain plug and filter were torqued on like hell though. Taking the filter off and whatever that box is behind it came off too. Scared the **** out of me I thought I broke something. Here are some pics.
<img src="http://i28.photobucket.com/albums/c233/a4wheelin/0627060945a.jpg">
<a href="http://photobucket.com" target="_blank"><img src="http://i28.photobucket.com/albums/c233/a4wheelin/0627060946.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
Not sure what component this is. It's in the center and rear of the tranny. It had a couple drops of oil on it, is this bad?
<a href="http://photobucket.com" target="_blank"><img src="http://i28.photobucket.com/albums/c233/a4wheelin/0627060954.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
Is this the rear diff? It was pretty much coated in dried up gooey oil. Normal?
<a href="http://photobucket.com" target="_blank"><img src="http://i28.photobucket.com/albums/c233/a4wheelin/0627060955a.jpg" border="0" alt="Photobucket - Video and Image Hosting"></a>
then keep an eye on it to see if it's leaking at all, and how much.
As for the part that the oil filter screws onto, I didn't know that it unscrewed also. Good to know in case it happens to me some day. I think there were some hoses attached to it. Did you make sure none of them got kinked or loosened?
I just put the old seal back on the oil cooler. I'll keep an eye on it. How do you check level on rear diff? Is there a sight glass or something?
remove it and the oil level should be level with the bottom of the hole. Just be sure the car is raised up level and not just jacked up in the back. You'll need 4 jack stands/ramps to do this.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
CPLYONS
09-07-2015 07:19 PM
audijim113
09-03-2015 01:22 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
