check engine light
#12
Most recently the problem has been availability. The latest part number (suffix) is L or M. I've had my L parts for 35k miles with no issues. Of course, my originals didn't fail, they were swapped as part of the recall.
good luck and let us know how things work out!
#13
In some cases, the failure results in practically a total loss of the ability to generate a spark at the plug, hence the continuous sputtering you mention. In another common coilpack failure mode, the severity of the degradation of the coilpack internal electrical components is less severe. In these cases, the coilpack fires the spark at the plug gap OK when engine cylinder pressure is comparatively low, but is not able to produce the ignition voltages required to force a spark to jump the plug gap at higher engine loads, when cylinder pressures increase beyond the ignition voltage limited value. (Spark "blow out")
Thus, the engine runs normally with small throttle opening angles, then collapses into misfire as the throttle is opened further.
carl viking
39
06-24-2024 09:17 AM
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
