CHIP info??? I need to be educated.
Old 05-14-2002, 04:11 PM
  #11
SKareKrow's Avatar
Because most companies solder a piece onto the ECU
Old 05-14-2002, 04:14 PM
  #12
AggregatVier's Avatar
The original is soldered to the board. It's REAL obvious it's been changed.
Old 05-14-2002, 06:05 PM
  #13
Junior Member
Paul H. (near Annapolis, MD)'s Avatar
Default In a nutshell..
On the 1.8T, the turbo is controlled by the same engine computer that controls fuel and timing. Chip tuners remap the programming to increase the boost provided by the turbo (sometimes by 2X), and adjust the timing and fuel to match. Many of the chips increase the power output by ~50 Hp and ~75 ft-lbs of torque. That is a significant increase.
In this economy, the bean counters do not let the engineers over-engineer the cars like they used to. The chances that things are going to break with this kind of power increase is much greater.
Audi designed the car and all of it's systems to function reliably within a certain power range, and doesn't think they should have to warranty items that break when the power output is increased beyond what they designed the car to handle. So they generally consider the warranty on powertrain components void if the car is chipped.
Paul
LaserSVT
RS 6 Discussion (C5)
07-22-2022 10:29 AM
vwleadfoot
Audi Original "S" Cars
12-24-2015 06:07 AM
BKDave
09-20-2015 04:34 PM
redliner996
09-14-2015 04:53 PM
Quick Reply: CHIP info??? I need to be educated.
