Coding Key
The other day when I did my timing belt I disconnected the battery now my remotes don't work. I was told there is a certain sequence when you put the key in the door and hit the unlock or lock buttons. nyone know?
This is what I did I hope this works.
-Get in the car, make sure all doors are closed
-Put the key in the ignition
-Start the car while holding the lock button on the remote
-Turn the car off
-And the remote should work.
-Turn the car off
Note: If the car has immobilizer, you have to take it to the dealer.
Otherwise, this should be the correct procedure:
1.Take one key/remote (key B) and put it in the ignition and turn the ignition ON (to the "accessory-on" position - don't start the car).
2.Close and lock the driver's door with the other key/remote (key A) while the ignition remains on.
3.Take the key A remote and press the "UNLOCK" button ONCE only - alarm will 'beep'/lights flash, but door will remain locked.
4.Wait for a slow count of 10.
5.With key A, unlock and lock the door again (using the key not the remote).
6.Test the remote by pressing the "UNLOCK" button again - door should unlock.
7.Open the door and turn ignition off and back on again using the key A this time.
8.Continue the procedure for the second remote - close & lock the door with the key B (leaving the ignition on).
9.Take key B remote and press the "UNLOCK" button TWICE - alarm will 'beep'/flash each time button is pressed but door will remain locked.
10.Wait a count of 10 again.
11.With key B, unlock and lock the door again (using the key not the remote).
12.Test the remote by pressing the "UNLOCK" button again - door should unlock.
13.Remove both keys, close the door and perform a final retest by locking and unlocking the car with both remotes.
If this doesn't work, repeat WITHOUT steps 5 & 11.
Sorry for the cut and paist from another site......
Don't like the site they try to infect your computer so I didn't paist just the link.
I did this but put my hand in the open drivers window with the key I was
programing in the door. And locked and unlocked the door with the botton in the door. Not the botton on the FOB.
Hope this helps?
Hope this helps?
yk7209
02-16-2016 12:54 PM
A4Novice
08-22-2010 05:55 PM
nemesisa6
02-03-2008 02:28 PM
audiringpwr
02-07-2003 04:42 PM
