Coil Pack? No. "Bad" Instrument cluster. Yes!
As I posted in another thread, the other night I thought I had finally come face to face with the dreaded coil pack issue. But it turns out that wasn't the case.
Instead, my fiance, who was driving the car in the middle of nowhere at the time, simply ran out of gas due to the bad instrument cluster/fuel gauge issue. It merely sounded like a coil pack thing based on the second-hand symptom description that I was given at the time.
From what I've been reading, this is a pretty common problem with a fairly easy solution. And my car had been exhibiting some of the now-recognized tell-tale signs -- such as being "put to bed" with 100-miles-to-0 and "waking up" with with a lot less, and regularly only going up to 3/4 full after filling up the tank.
My only question relates to underlying electrical issues. In the past couple of months I've also had to replace both front turn signal bulbs. Which strikes me as a little odd, since such minimally used parts shouldn't burn out in less than 16k miles. So I'm wondering whether there might be a kink in the electrical system somewhere -- sending out surges perhaps? -- that's straining the various electrical components and causing them to fail. Is that likely? Or even possible?
Thanks in advance for the input.
Rob
Rob
after they began failing intermittently. Left onw last May, right one in November. Turns out, the connector that the bulb sits in had started to melt down.
Luckily though, I haven't had any other electrical issues with the car ... other than two coilpacks failing.
..."I haven't had any other electrical issues ... other than two coilpacks..." actually sounds strangely rational. ![Smile](https://www.audiworld.com/forums/images/smilies/smile.gif)
I sure hope that the list of "nothing other than _____" doesn't get significantly longer over time...
S4intheOC
09-08-2015 12:12 AM
anticsAK
09-06-2015 05:34 AM
anticsAK
09-04-2015 09:59 PM
