coil survey......
coil survey......
SURVEY:
(1) CAR ... Describe your car:
Make _audi__
Model _a4___
Year __02_____
Engine type __1.8t_____
Auto/Manual ___m____
FWD/AWD _fwd______
(2) __c___ NUMBER OF FAILURES ... Is this survey for your:
A ... 1st. Coil failure
B ... 2nd. Coil failure
C ... 3rd. Coil failure
D ... 4th. Coil failure
SYMPTOMS ... Check all that apply:
A __/_ Shaking
B _/__ Vibration
C __/_ Rough Idle
D __/_ Flashing Engine Warning Light
E ___ Steady Engine Warning Light
F ___ Minor loss of power while driving
G __/_ Moderate loss of power whild driving
H ___ Major loss of power while driving
I ___ Total loss of power while driving
J ___ Could not keep the engine running
K ___ Didn't try to drive it
3a .. Do you have any other comments regarding the symptoms you experienced:
_______________________________
(4) 1st _e____ 2nd __e___ 3rd _a____ 4th _____ WHEN FIRST NOTICED ... Did you first notice the problem:
A ... Upon starting your car
B ... After starting your car but before driving away
C ... Within 5 minutes of starting your car and driving away
D ... On the road - Inconvenience but not hazardous
E ... On the road - Hazardous situation - Traffic
F ... On the road - Hazardous situation - Weather
G ... On the road - Hazardous situation - Bad place to be stranded
4a .. Do you have any additional comments regarding the above:
(5) 1st __d___ 2nd __d___ 3rd c_____ 4th _____ WEATHER ... Was the weather:
A ... Hot (85 degrees or higher)
B ... Mild (between 50 and 85 degrees)
C ... Cold - Above Freezing (between 32 and 50 degrees)
D ... Cold - Below Freezing (below 32 degrees)
5a .. Do you have any other comments regarding the weather (snow, rain, sleet, etc):
________________________________
(6) 1st _g____ 2nd ___g__ 3rd _g____ 4th _____ AFTER THE FAILURE OCCURRED ... Once you noticed this problem
with your car what did you do:
A ... Turned off the ignition ... Had it flatbedded to the dealer
B ... Pulled to the side of the road ... had it flatbedded to the dealer
C ... Drove to a safe parking spot ... Had it flatbedded to the dealer
D ... Drove until you felt you were a traffic hazard and concerned for your safety ... Have it flatbedded to the dealer
E ... Drove until additional symptoms made you too concerned to drive further ... Had it flatbedded to the dealer
F ... Drove home ... Had it flatbedded to the dealer
G ... Drove directly to the dealer
6a .. Any other comments regarding the above:
_______________________________________
(7) __c___ DRIVING STYLE ... Is your driving style typically:
A ... Gentle
B ... Moderate
C ... Moderate and sometimes aggressive
D ... Aggressive and sometimes moderate
E ... Aggressive
(8) __b___, __c___ DEALER RESPONSES (select 2) ... What did your dealer tell you when the car was brought in:
A .. Car ready .. Or ... Will be ready within one day.
B ... Parts are on order. One week estimate.
C ... Parts are on order. Two week estimate.
D ... Parts are on order. Three week estimate.
E ... Parts are on order. Estimate more than 3 weeks.
F ... Parts are on order. No idea of when they'll be in.
G ... Transportation, if needed, was provided for.
H ... Transportation, although needed, was not provided for.
J ... Comments _________________________
(9) 1st __c___ 2nd c_____ 3rd _c____ 4th _____ COIL REPLACEMENT ... If your engine is a 1.8T, Did the dealer replace
your coil with the latest revision coil (Part # 06B-905-115-J for 1.8T -or- 06C-905-115-E for 3.0):
A ... Yes
B ... No
C ... Don't know
(10) 1st __b___ 2nd _b__ 3rd __b___ 4th _____ 'ALL' COIL REPLACEMENT ... Did the dealer replace 'all' your coils with
the latest revision ignition coils?:
A ... Yes
B ... No
C ... Don't know
(11) - LOCATION ... Geographically, where did the failure occur (Closest major city and State or Province):
1st ___bridgeport,connecticut_________________________ ___________
2nd _______________________________________
3rd _______________________________________
4th _______________________________________
(12) - MILEAGE ... What was the mileage on your car when your coil failure occurred.
1st _7165______________________________________
2nd _7989______________________________________
3rd _8469______________________________________
(13) - WHEN ... In what 'month' and 'year' did this failure occur:
1st _11-02______________________________________
2nd __12-02_____________________________________
3rd __1-03_____________________________________
(14) - CAR BUILD DATE ... When was your car built (month/year) ... (Look inside your driver door pillar for build date).
Write the date or write in your purchase date with an asterisk.
__4-02_________________________________________
(15) _c_____ DISRUPTION ... How serious was the effect of this problem on your planned activities ...
A ... Negligable .. Comments __________________________
B ... Minor .. Comments ______________________________
C ... Significant .. Comments __________________________
A ... Major .. Comments ______________________________
(16) - VENTING AND CUSSING ... Add any comments below that you'd like to share:
nohat ive experienced this three times im really nervous to take my car on a long trip...help AoA
Make _audi__
Model _a4___
Year __02_____
FWD/AWD _fwd______
A __/_ Shaking
B _/__ Vibration
C __/_ Rough Idle
A ... Gentle
B ... Moderate
E ... Aggressive
A ... Yes
B ... No
C ... Don't know
A ... Yes
B ... No
C ... Don't know
Audi Other 6 speed 2003 Audi RS6
alpinab7
10-07-2015 10:13 PM
