Control Arm Brand. Who makes the better control arms? Febi/bilstein, Meyle or TRW?
#11
reintroduced into the aftermarket retail channel. Avoid Meyle. Febi/Bilstein would be my second place choice. TRW third.
#12
the fail early, but the part that fails is not the same.
The B6 has issue with the upper arm rubber bushing going away.
I'm under 70K miles on my S4 and the upper arm bushings are toast... I need to get them replaced.
#13
if you want to do the labor, you can get those bushings for $20 each.. $80 to do all 4 uppers isn't a bad deal, if you can deal with the work involved.
#16
on the B5 it was a bitch because of the pinch bolt.
You'll need two pieces of pipe, one slightly smaller than the control arm, but still has enough surface area on the metal of the bushing. And one larger than the opening on the control arm.
Then you can put them in a 5" bench vise and push them out
example on a b5 passat<ul><li><a href="http://home.comcast.net/~hhong4/kmacinstall.htm">http://home.comcast.net/~hhong4/kmacinstall.htm</a</li></ul>
the_duke
09-10-2015 09:02 AM
CPLYONS
09-07-2015 07:19 PM
ECS Tuning-Audi
09-01-2015 12:25 PM
