Cooling Fans Turn on when car is OFF - Help please
I recently had my car in for service and they told me that i needed to replace my cooling control module which is located right by the front hood latch. My car was overheating at idle and ac wouldn't work right. So last night my battery dies on my and i dont know why, i got it pushed and pop clutch start it again.. The car was dead again this morning when i fiqured out the fans are turning on.. Then today i replaced the cooling fan module and now this problem won't go away... but my car doesn't over heat at idle and ac works good. so i disconnected the wire going to the harness so the fans won't turn on when the car is off cause it drains my battery.. Is there a vag code i can recode with ? TIAS
3 Faults Found:
16804 - Catalyst System; Bank 1: Efficiency Below Threshold
P0420 - 002 - Lower Limit Exceeded - Intermittent
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
18080 - Coolant Fan Control 1: Open or Short to Ground
P1672 - 004 - No Signal/Communication - Intermittent
Readiness: 0000 0000
The problem could be the secondary air pump operating with ignition off. It will run the battery down overnight. The problem is a relay switch. The Audi part number 141-951-253-B.
I have the 18080 fault the left fan stays on not the air con fan the engine fan which module did you replace? anyone else with this fault 2003 s4
carl viking
40
07-12-2024 02:45 PM
N'Syncro
33
02-16-2020 03:12 PM
