CPM, another coilpack failure to log
SURVEY:
(1) CAR ... Describe your car:
Make Audi
Model A4
Year 2002
Engine type 1.8T
Auto/Manual Manual
FWD/AWD FWD
(2) ___A__ NUMBER OF FAILURES ... Is this survey for your:
A ... 1st. Coil failure
B ... 2nd. Coil failure
C ... 3rd. Coil failure
D ... 4th. Coil failure
SYMPTOMS ... Check all that apply:
A _X__ Shaking
B _X__ Vibration
C _X__ Rough Idle
D _X__ Flashing Engine Warning Light
E ___ Steady Engine Warning Light
F ___ Minor loss of power while driving
G ___ Moderate loss of power whild driving
H ___ Major loss of power while driving
I ___ Total loss of power while driving
J ___ Could not keep the engine running
K _X__ Didn't try to drive it
3a .. Do you have any other comments regarding the symptoms you experienced:
_______________________________
(4) 1st _B___ 2nd _____ 3rd _____ 4th _____ WHEN FIRST NOTICED ... Did you first notice the problem:
A ... Upon starting your car
B ... After starting your car but before driving away
C ... Within 5 minutes of starting your car and driving away
D ... On the road - Inconvenience but not hazardous
E ... On the road - Hazardous situation - Traffic
F ... On the road - Hazardous situation - Weather
G ... On the road - Hazardous situation - Bad place to be stranded
4a .. Do you have any additional comments regarding the above:
(5) 1st __D___ 2nd _____ 3rd _____ 4th _____ WEATHER ... Was the weather:
A ... Hot (85 degrees or higher)
B ... Mild (between 50 and 85 degrees)
C ... Cold - Above Freezing (between 32 and 50 degrees)
D ... Cold - Below Freezing (below 32 degrees)
5a .. Do you have any other comments regarding the weather (snow, rain, sleet, etc):
It snowed all weekend, and it was snowing a little when it happened. The car had sat over the weekend in the snow before the failure occured.
(6) 1st __A___ 2nd _____ 3rd _____ 4th _____ AFTER THE FAILURE OCCURRED ... Once you noticed this problem
with your car what did you do:
A ... Turned off the ignition ... Had it flatbedded to the dealer
B ... Pulled to the side of the road ... had it flatbedded to the dealer
C ... Drove to a safe parking spot ... Had it flatbedded to the dealer
D ... Drove until you felt you were a traffic hazard and concerned for your safety ... Have it flatbedded to the dealer
E ... Drove until additional symptoms made you too concerned to drive further ... Had it flatbedded to the dealer
F ... Drove home ... Had it flatbedded to the dealer
G ... Drove directly to the dealer
6a .. Any other comments regarding the above:
_______________________________________
(7) _B____ DRIVING STYLE ... Is your driving style typically:
A ... Gentle
B ... Moderate
C ... Moderate and sometimes aggressive
D ... Aggressive and sometimes moderate
E ... Aggressive
(8) __A___, __G___ DEALER RESPONSES (select 2) ... What did your dealer tell you when the car was brought in:
A .. Car ready .. Or ... Will be ready within one day.
B ... Parts are on order. One week estimate.
C ... Parts are on order. Two week estimate.
D ... Parts are on order. Three week estimate.
E ... Parts are on order. Estimate more than 3 weeks.
F ... Parts are on order. No idea of when they'll be in.
G ... Transportation, if needed, was provided for.
H ... Transportation, although needed, was not provided for.
J ... Comments _________________________
(9) 1st ___A__ 2nd _____ 3rd _____ 4th _____ COIL REPLACEMENT ... If your engine is a 1.8T, Did the dealer replace
your coil with the latest revision coil (Part # 06B-905-115-J for 1.8T -or- 06C-905-115-E for 3.0):
A ... Yes
B ... No
C ... Don't know
(10) 1st __B___ 2nd _____ 3rd _____ 4th _____ 'ALL' COIL REPLACEMENT ... Did the dealer replace 'all' your coils with
the latest revision ignition coils?:
A ... Yes
B ... No
C ... Don't know
(11) - LOCATION ... Geographically, where did the failure occur (Closest major city and State or Province):
1st Philadelphia, PA_______________________
2nd _______________________________________
3rd _______________________________________
4th _______________________________________
(12) - MILEAGE ... What was the mileage on your car when your coil failure occurred.
1st 24000__________________________________
(13) - WHEN ... In what 'month' and 'year' did this failure occur:
1st January 2003___________________________
(14) - CAR BUILD DATE ... When was your car built (month/year) ... (Look inside your driver door pillar for build date).
Write the date or write, "Don't know".
__9/01_______________________________________
(15) __n/a____ FOLLOW-UP ... Will you be providing follow-up answers to any questions where "don't know" was your answer
on this survey:
A ... Yes
B ... No
C ... I'll try to remember to do so
(16) - VENTING AND CUSSING ... Add any comments below that you'd like to share:
argh.
Make Audi
Model A4
Year 2002
Engine type 1.8T
Auto/Manual Manual
FWD/AWD FWD
A _X__ Shaking
B _X__ Vibration
C _X__ Rough Idle
A ... Gentle
B ... Moderate
E ... Aggressive
A ... Yes
B ... No
C ... Don't know
A ... Yes
B ... No
C ... Don't know
on this survey:
A ... Yes
B ... No
argh.
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
Cmmartin23
26
08-23-2016 04:44 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
