For CPM, Here is your survey
SURVEY:
(1) CAR ... Describe your car:
Make _______
Model 1.8t______
Year 2002_______
Engine type _______
Auto/Manual _auto______
FWD/AWD __awd_____
(2) _3____ NUMBER OF FAILURES ... Is this survey for your:
A ... 1st. Coil failure
B ... 2nd. Coil failure
C ... 3rd. Coil failure
D ... 4th. Coil failure
SYMPTOMS ... Check all symptoms that occurred for each failure:
A .X.. 1st_____2nd_____3rd_____4th_____Shaking
B ..X. 1st_____2nd_____3rd_____4th_____ Vibration
C ..X. 1st_____2nd_____3rd_____4th_____Rough Idle
D ..X. 1st_____2nd_____3rd_____4th_____Flashing Engine Warning Light
E ... 1st_____2nd_____3rd_____4th_____Steady Engine Warning Light
F ... 1st_____2nd_____3rd_____4th_____Minor loss of power while driving
G ..X. 1st_____2nd_____3rd_____4th_____Moderate loss of power whild driving
H ... 1st_____2nd_____3rd_____4th_____Major loss of power while driving
I ... 1st_____2nd_____3rd_____4th_____Total loss of power while driving
J ... 1st_____2nd_____3rd_____4th_____Got progressively worse with time.
K ... 1st_____2nd_____3rd_____4th_____Could not keep the engine running
L ... 1st_____2nd_____3rd_____4th_____Didn't try to drive it
3a .. Do you have any other comments regarding the symptoms you experienced:
_______________________________
(4) 1st _____ 2nd __X___ 3rd _____ 4th _____ WHEN FIRST NOTICED ... Did you first notice the problem:
A ..X. Upon starting your car
B ... After starting your car but before driving away
C ..X. Within 5 minutes of starting your car and driving away
D ... On the road - Inconvenience but not hazardous
E ... On the road - Hazardous situation - Traffic
F ... On the road - Hazardous situation - Weather
G ... On the road - Hazardous situation - Bad place to be stranded
4a .. Do you have any additional comments regarding the above:
(5) 1st _____ 2nd _____ 3rd _____ 4th _____ WEATHER ... Was the weather:
A ... Hot (85 degrees or higher)
B ... Mild (between 50 and 85 degrees)
C ... Cold - Above Freezing (between 32 and 50 degrees)
D ..X. Cold - Below Freezing (below 32 degrees)
5a .. Do you have any other comments regarding the weather (snow, rain, sleet, etc):
________________________________
(6) 1st _____ 2nd __X___ 3rd _____ 4th _X____ AFTER THE FAILURE OCCURRED ... Once you noticed this problem
with your car what did you do:
A ..X. Turned off the ignition ... Had it flatbedded to the dealer
B ... Pulled to the side of the road ... had it flatbedded to the dealer
C ... Drove to a safe parking spot ... Had it flatbedded to the dealer
D ... Drove until you felt you were a traffic hazard and concerned for your safety ... Have it flatbedded to the dealer
E ... Drove until additional symptoms made you too concerned to drive further ... Had it flatbedded to the dealer
F ... Drove home ... Had it flatbedded to the dealer
G ... Drove directly to the dealer
6a .. Any other comments regarding the above:
_______________________________________
(7) _____ DRIVING STYLE ... Is your driving style typically:
A ... Gentle
B ... Moderate
C ..X. Moderate and sometimes aggressive
D ... Aggressive and sometimes moderate
E ... Aggressive
(8) 1st _____ 2nd _____ 3rd _____ 4th _____ DEALER RESPONSES ... What did your dealer tell you when the car was brought in:
A .X. Car ready .. Or ... Will be ready within one day.
B ... Parts are on order. One week estimate.
C ... Parts are on order. Two week estimate.
D ... Parts are on order. Three week estimate.
E ... Parts are on order. Estimate more than 3 weeks.
F ... Parts are on order. No idea of when they'll be in.
J ... Comments _________________________
(9) 1st _____ 2nd _____ 3rd _____ 4th _____ COIL REPLACEMENT ... Did the dealer replace
your coil(s) with the latest revision coil (Part # 06B-905-115-J for 1.8T -or- 06C-905-115-E for 3.0):
A ..X. Yes
B ... No
C ... Don't know
(10) 1st _____ 2nd _____ 3rd _____ 4th _____ 'ALL' COIL REPLACEMENT ... Did the dealer replace 'all' your coils?
A ..X. Yes,
#2, #3, #4 CP blow within three months and my dealer had replaced the last CP without failure.
B ... No
C ... Don't know
(11) - LOCATION ... Geographically, where did the failure occur (Closest major city and State or Province):
1st ______Ottawa_________________________________
2nd ______Toronto___________________________
3rd ______Ottawa_________________________________
4th _______________________________________
(12) - MILEAGE ... What was the mileage on your car when your coil failure occurred.
1st ____________7000km___________________________
2nd ____________9000km___________________________
3rd ____________9500km___________________________
(13) - WHEN ... In what 'month' and 'year' did this failure occur:
1st _____________Nov 2002________________________
2nd _____________Jan 2003_______________________
3rd ______________Jan 2003______________________
(14) - CAR BUILD DATE/PURCHASE DATE ... When was your car built/delivered (month/year) ... (Look inside your driver door pillar for build date).
Build date: ___________April 2002_______________
Date you took delivery: _________June 2002______
(15) 1st _____ 2nd _____ 3rd _____ 4th _____ DISRUPTION ... How serious was the effect of this problem on your planned activities ...
A ... Negligable .. Comments __________________________
B ..X. Minor .. Comments ______________________________
C ... Significant .. Comments __________________________
D ... Major .. Comments ______________________________
(16) 1st _____ 2nd _____ 3rd _____ 4th _____INDICATORS ... In days prior to your coil failure, did your car provide any hints that car trouble was brewing such as:
A ... Change in the way the car idles
B ... Recent change in the way the car starts
C ..X. Poorer than normal gas mileage
D ... Other _________________________________________
(17) 1st _____ 2nd _____ 3rd _____ 4th _____FAILED COIL ... If you know for certain the part number or the revision of the coil(s) that failed, please note it here: (If you get a chance, please ask. There are rumors of failures of the latest rev coils. We need substantiation).
A .X.. 1.8t Part # 06B-905-115-H (Rev H)
B ... 1.8T Part # 06B-905-115-J (Rev J)
C ... 3.0 Part # 06C-905-115-D (Rev D)
D ... 3.0 Part # 06C-905-115-E (Rev D)
E ... Other ______________________
F ... Don't know for sure
(18) _____ NUMBER OF SURVEYS SUBMITTED ... Please indicate the number of 'Failed Coilpack' surveys or questionnaires you've filled out for us (including this one):
A ... One
B .X.. Two
C ... Three
D ... Four
(19) - VENTING AND CUSSING ... Add any comments below that you'd like to share:
My dealer had told me Audi Canada agrees to replace all the CPs that with the old version (H series)even without failure to them.
Make _______
Model 1.8t______
Year 2002_______
Engine type _______
FWD/AWD __awd_____
A ... Gentle
B ... Moderate
E ... Aggressive
A ..X. Yes
B ... No
C ... Don't know
A ..X. Yes,
B ... No
C ... Don't know
A ... One
B .X.. Two
C ... Three
D ... Four
Got it ... Logged it ... Thanks a lot 02A400A4!
User account number (aid): 34877
Posted by 02A400A4 on 2003-01-28 16:20:46
SURVEY:
Make _______
Model 1.8t______
Year 2002_______
Engine type _______
FWD/AWD __awd_____
A ... Gentle
B ... Moderate
E ... Aggressive
A ..X. Yes
B ... No
C ... Don't know
A ..X. Yes,
B ... No
C ... Don't know
A ... One
B .X.. Two
C ... Three
D ... Four
SURVEY:
Make _______
Model 1.8t______
Year 2002_______
Engine type _______
FWD/AWD __awd_____
A ... Gentle
B ... Moderate
E ... Aggressive
A ..X. Yes
B ... No
C ... Don't know
A ..X. Yes,
B ... No
C ... Don't know
A ... One
B .X.. Two
C ... Three
D ... Four
the_duke
09-10-2015 09:02 AM
Firebug
02-10-2000 07:31 PM
SURVEY: anyone find their chipped 1.8 to be faster than they can believe? I can't stop driving mine!
trying to stay out of trouble with this thing
02-08-2000 07:49 AM
Albert
10-26-1998 02:12 PM
