cranking but wont start with codes
2002 a4 b6 1.8t
Swapped fuel pump and relay
Coils then got a hold of vagcom
Tuesday,28,February,2012,20:46:45:28157 2. VCDS Version: Release 11.11.2 3. Data version: 20120126 4. 5. 6. Chassis Type: 8E - Audi A4 B6/B7 7. Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67 8. 69 75 76 77 9. 10. VIN: WAUJC68E22A203710 Mileage: 187350km/116413miles 11. -------------------------------------------------------------------------------
Labels: 8E0-614-517.lbl
12. Address 03: ABS Brakes
13. Part No: 8E0 614 517 14. Component: ABS/ESP front 1726 15. Coding: 04275 16. Shop #: WSC 06435 17. VCID: E5CAB8447F7A67B 18. 19. 3 Faults Found: 20. 01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30 21. 35-00 - -22. 18258 - Powertrain Data Bus 23. P1850 - 35-00 - Missing Message from ECU 24. 18258 - Powertrain Data Bus 25. P1850 - 35-00 - Missing Message from ECU 26. 27. -------------------------------------------------------------------------------
Labels: 8E0-820-043.lbl
28. Address 08: Auto HVAC
29. Part No: 8E0 820 043 AG 30. Component: A4 Klimaautomat 1424 31. Coding: 00000 32. Shop #: WSC 00000
VCID: 66C83F48027CEC3
33.
34. 35. No fault code found. 36. 37. -------------------------------------------------------------------------------38. Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.lbl 39. Part No: 8E0 907 279 E 40. Component: int. Lastmodul USA 0305 41. Coding: 00003
Shop #: WSC 63351
42.
43. VCID: 346C950004204E3 44. 45. No fault code found. 46. 47. -------------------------------------------------------------------------------48. Address 15: Airbags Labels: 8E0-959-655-84.lbl 49. Part No: 8E0 959 655 A
4000
Component: Airbag 8.4E
50.
51. Coding: 0010607 52. Shop #: WSC 63351 000 00000 53. VCID: 356AA8045F5A57B 54. 55. No fault code found. 56. 57. -------------------------------------------------------------------------------
Labels: 8E0-953-549.lbl
58. Address 16: Steering wheel
59. Part No: 8E0 953 549 L 60. Component: Lenksáulenmodul 0308 61. Coding: 00041 62. Shop #: WSC 63351
VCID: 3C7CBD202C70863
63.
64. 65. No Faults Found 66. or DTCs not supported by controller 67. or a communication error occurred 68. 69. -------------------------------------------------------------------------------70. Address 17: Instruments Labels: 8E0-920-9xx-8E2.lbl
Part No: 8E0 920 950 H
71.
72. Component: KOMBI+WEGFAHRS. RB4 D26 73. Coding: 02200 74. Shop #: WSC 05141 75. VCID: 2E588768EA0C643 76. WAUJC68E22A203710 AUZ6Z0A0347293 77. 78. No fault code found. 79. 80. -------------------------------------------------------------------------------81. Address 45: Inter. Monitor Labels: 8E0-951-177.lbl 82. Part No: 8E0 951 177 83. Component: Innenraumueberw. 0504 84. Coding: 00001
Shop #: WSC 00000
85.
86. VCID: EBDECE7C999E51B 87. 88. No fault code found. 89. 90. -------------------------------------------------------------------------------91. Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl 92. Part No: 8E0 959 433 T
0617
Component: Komfortgerát T5B
93.
94. Coding: 11788 95. Shop #: WSC 63351 96. VCID: 4280C3D84E94F03 97. 98. Subsystem 1 - Part No: 8E1959801B 99. Component: Tőrsteuer.FS BRM 0002 100. 101. Subsystem 2 - Part No: 8E1959802E 102. Component: Tőrsteuer.BF BRM 0002 103. 104. Subsystem 3 - Part No: 8E0959801A 105. Component: Tőrsteuer.HL BRM 0002 106. 107. Subsystem 4 - Part No: 8E0959802A
Component: Tőrsteuer.HR BRM 0002
108.
109. 110. 1 Fault Found: 111. 01331 - Door Control Module; Driver Side (J386) 112. 80-00 - Single-Wire Operation 113. 114. -------------------------------------------------------------------------------115. Address 56: Radio Labels: 8E0-035-1xx-56.lbl 116. Part No: 8E0 035 195 A
0008
Component: symphony II NP2
117.
118. Coding: 01001 119. Shop #: WSC 40626 120. VCID: 254A7844BFFA27B 121. 122. No fault code found. 123. 124. End ---------------------------------------------------------------------
33.
Shop #: WSC 63351
42.
4000
50.
63.
71.
Shop #: WSC 00000
85.
0617
93.
108.
0008
117.
As far as the stuff from VAGCOM you put in the thread, that looks like a bunch of config stuff, not the actual codes. The codes are much shorter and succinct.
As far as not starting, when this happened to me, it was the ESS, or engine speed sensor. This should pop up in the codes area of VAGCOM. Link below which has a second link to a DIY.
https://www.audiworld.com/forums/sho...&highlight=ess
69 75 76 77
Address 03: ABS Brakes Labels: 8E0-614-517.lbl
Coding: 04275
Shop #: WSC 06435
3 Faults Found:
35-00 - -
Address 08: Auto HVAC Labels: 8E0-820-043.lbl
Coding: 00000
Shop #: WSC 00000
Coding: 00003
Shop #: WSC 63351
Component: Airbag 8.4E 4000
Coding: 0010607
Address 16: Steering wheel Labels: 8E0-953-549.lbl
Coding: 00041
Shop #: WSC 63351
No Faults Found
Coding: 02200
Shop #: WSC 05141
Coding: 00001
Shop #: WSC 00000
Component: Komfortgerát T5B 0617
Coding: 11788
Shop #: WSC 63351
1 Fault Found:
Component: symphony II NP2 0008
Coding: 01001
Shop #: WSC 40626
69 75 76 77
Coding: 04275
Shop #: WSC 06435
3 Faults Found:
35-00 - -
Coding: 00000
Shop #: WSC 00000
Coding: 00003
Shop #: WSC 63351
Coding: 0010607
Coding: 00041
Shop #: WSC 63351
No Faults Found
Coding: 02200
Shop #: WSC 05141
Coding: 00001
Shop #: WSC 00000
Coding: 11788
Shop #: WSC 63351
1 Fault Found:
Coding: 01001
Shop #: WSC 40626
Don't see anything in that list which would not allow the car to start and never read a situation where it wouldn't start without any indication why. Did this just suddenly happen? Are there any lights at all? Any maintenance / repairs / dead battery / rain / etc, etc?
Can you hear the fuel pump prime when you turn the key to ON? That's the problem I have at the moment... no fuel pump noise. Although my relay is good and the pump kicks on when I jump the fuse.
It clicks but doeant prime. Since address 1 and 2 don't show I am worries it is the ecu or ecu relay. From what I was reading it is relay 30 so I am going to see if I can play with that.
Very heavy rain but nothing other than that. Never had starting issues before this.
I cant test the ecu but did jump the fan relay and the fan kicked on when I tried cranking (relay that powers ecu?). I really think it is the ecu, or a wiring issue, but have no idea how to replace it without going to a dealer. Worried if I buy a used ecu for $100 on eBay the Immobilizer will screw that up for me. Any ideas? Thanks!
I would check the relays underneath the ECU first. You may find them corroded and ust need replacing. Make sure you get the drains working while it is apart.
Garrett's S4
VAG-COM Discussion
02-07-2009 07:03 AM
joeycuccaro
NY / NJ / CT Discussion
11-11-2008 08:43 AM
