Curious....anyone running the ecode tuning test pipe? thoughts?
I already have thermal exhaust and the test pipe would make it that much better
Ive heard that it makes your exhaust more throaty and louder, and you get some good gains espcecially in conjunction with an exhaust...but ive also heard that it causes a cel.
There was a post about spacing the rear O2 sensor using HELP! spark plug arrestors (available at most auto parts stores).
It keeps the rear O2 out of direct exhaust flow which reduces the chances of a CEL.
It is just used for monitoring cat efficiency sp? and will throw a dtc if the voltage is too hi or low or stuck at the same value. I dont think there are any O2 simulators for our cars like the B5 guys and BMW guys are running.
He could always let the light come on and install a good a/f sensor/gauge, and a egt sensor
The only limitation appears to be the speed of the data software from vagcom but that may be rectified with the new CAN software, i just havent tried it. It seems to work fine though if you measure one block at a time. cheers! Mike
I know for the WRX they use the helix, all it is, is a small resistor that goes inline. Since they are obd 2 as well as are car it should function the same because obd 2 serves the same base function no matter what car. I run a 3 inch down pipe custom made for the same price as the ecode and as soon as I installed revo it went away. So there is something to bypass the light. The resistor is a cheap way to take a shot with nothing to lose cause it just goes inline! give it a shot!
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
ECS Tuning-Audi
09-01-2015 08:27 AM
