Curious... those of you who run a K04 + HFC, what was the effect [if any?] after installing the HFC?
#11
No...
I ran a test-pipe on my A4 for nearly a year, with the K04. With my Thermal exhaust, it was loud! I thought I could sneak a HJS HFC out of Germany,(but found out after the fact, HJS sent their cats to the UK, to the same people who weld up and fabricate the Milltek cats) so I installed the Milltek(AKA HJS), and it quieted my exhaust down, and slowed the turbo's spool up ever so slightly, compaired to the test-pipe.
The main advantage of the HFC, is it pass's USA emissions tests and still flows exhaust very well! NO CEL!
In the state I live in I'm OBD tested every year.
Fail it, the state fines you! Especially if they catch you "altering the emissions system".
If you have ever tried and swap out the test-pipe every year, and have the turbo bolts sieze on you, you will be thankful for the HFC. Even DIY'n the test-pipe or HFC is a PITA, and to do it every year.....
Lots of folks bitch about the price of the Milltek HFC, but those of us who have'm, "know" how they perform.
Yes, you may not get any higher numbers on the dyno, but is driving a street driven car all about numbers on a dyno?
I've posted here several times, about the results of the HFC on my K04 equipped A4. For me it makes a noticable difference, especially compaired to the OEM CAT, or test-pipe.
If I could I'd take all the nay-sayer's for a test-drive, so they could see for them selves, what a difference the HFC makes.
Where's TigerClaw when ya need him? ;o)
#12
Finally. I was waiting for you to weigh in, MikTip. And yes...
where is Roman?
My bad for not STFA. Now that I think about it, I'm sure you posted something about this. Thanks for clarifying.
I'm in CA and don't plan on monkeying around w/test pipe removals when I have to get a Smog Inspection so it's HFC or OEM for me. But it seems that unless I'm running a giant turbo, there's really no need for a HFC.
#13
I agree, the "area under the torque curve" is a lot more important than peak hp, for a street ...
driven setup. I don't know if the tests done comparing a HFC with a stock cat, considered this. BTW, it seems "tgrclw" has forsaken us on this forum, haven't seen a post in a long time now.
#14
I am running a HFC that was relocated down past the downpipe. It will be getting
pulled out in a couple weeks as it appears to have gotten broken or melted as my temps have gone up since the past couple track days. I don't think that HFC's and trackdays are always the best combo.
#15
Exactly. I'm trying to figure out if certain components will have different effects on...
a particular setup. Like installing a really oversized FMIC will decrease spool up w/a K03 or certain manifolds will smooth out the torque curve with a K04.
And as for The Clw, I have faith he'll return in good time.
#17
Yup. That's what prompted me to ask about the HFC. More elements like that. Side note...
034 has their own and is doing some custom ones as well.<ul><li><a href="http://www.034motorsport.com/product_info.php?cPath=28_61&products_id=784"> 034 Motorsport Manifold</a></li></ul>
#18
Looks too much like ATP's old manifold....
ATP has a new and improved version of their old manifold. Then suddenly tuners starting selling the ATP look-a-likes as their own...Hmmmm?
N'Syncro
33
02-16-2020 03:12 PM
xkahn
02-08-2018 10:43 AM
CPLYONS
09-07-2015 07:19 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
