damn, think k04 just died or is it something else?
car warmed up fine this morning, drve on freeway fine but not much power. slam on gas, boost only jumps to around 10 psi--barely any power. dont hear turbo spooling but also dont hear dentist drill. not coilpack, engine idles fine and not shakey--probably not a boost leak either since car holds idle and doesnt die--or is it? never came across this yet. havent vagged 2 check.
k04, apr 1plus, thermal exhaust, fmic, larger tip,tt injectors. k04 has been 20k miles only, been chipped since 20k.
any ideas? thanks...
no, forgot to mention i have baileys.
thanks for the update mang. havent pulled codes--no check engine light anyway. i'll probably drop it off at the shop monday for them to look at. thanks mang.
pulled codes but not sure where the issue is. bringing it to shop tomorrow
issue might be in the HVAC area
ENGINE
3 Faults Found:
16396 - Bank 1: Camshaft A (Intake): Advance Setpoint not Reached (Over-Retarded)
P0012 - 001 - Upper Limit Exceeded - Intermittent
16725 - Camshaft Position Sensor (G40): Implausible Signal
P0341 - 004 - No Signal/Communication - Intermittent
16618 - Boost Pressure Regulation: Limit Exceeded (Overboost Condition)
P0234 - 001 - Upper Limit Exceeded
AUTO HVAC
1 Fault Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-00 - Blocked or No Voltage
ENGINE
3 Faults Found:
AUTO HVAC
1 Fault Found:
Sounds like you are...
<center><img src="http://www.purems.com/images/datapage/058905161B_dp.jpg"></center><p>in some sort of limp mode because your Cam sensor is going. The engine is having a hard time determining the proper timing, thus the limp mode.<ul><li><a href="http://www.purems.com/products/product.php/II=1462">Cam sensor</a></li></ul>
sweet! thanks man. I just dropped off the car to the shop
they can assess it. need coolant flush on my car anwyay so might as well have them do it. Thanks for all your help!
uble1234
14
10-23-2020 08:07 PM
