Diagnosticator :) How can i be so low on boost without throwing an underboost code?
I have a low boost scenario; intermittent. no codes at all.
All maintenance on my car done religiously.
Only thing suspect is several year old non-attended forge diverter.
Stage 1+ requests 2500mbar; several days in last week felt like 7psi.
then suddenly back to normal (same driving time no key out).
No codes; no underboost; nada.
Even though it felt like boost was only 7 psig, what was the actual boost achievement when torque was below expected? The first thing that I think of with the intermittent symptom, is a sticky mechanical item like the wastegate, or as you mentioned, the Forge DV. And, relative to the stock boost range, 7 psig may not be low enough to set a low boost DTC. Your concern that the DV needs cleaning/greasing is probably involved.
If the symptom reoccurs after servicing the DV,check the wastegate for smooth stroke without sticking partially open. Some DTCs require the fault to exist beyond a certain time period before the relevant code will be stored.
ECS Tuning-Audi
09-08-2015 01:08 PM
ECS Tuning-Audi
09-08-2015 11:47 AM
ECS Tuning-Audi
09-08-2015 10:42 AM
raiderrider
12
09-08-2015 05:46 AM
