DIY: Cerakote rear caliper coating
WARNING: I like red, when the funds become available, I want to get a red StopTech BBK. I chose red to coat my rear calipers, it may not be everyone's cup of tea. Feel free to flame me if you must, I won't cry. That said, on with the write-up.
I bought a set of used rear calipers through car-parts.com.
<img src="http://i132.photobucket.com/albums/q33/x1rider/brakecoating2.jpg">
I only coated one because I broke the other one taking it apart.
First step is to clean the caliper with acetone (in case you are wondering why the caliper is so shiny, it's because I sandblasted it a few months ago to try my sandblaster). I also masked the places I didn't want coated with foil so that it would tolerate the heat from the oven.
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali1.jpg">
Next I sanblasted (I did it again to remove any oxide layer that might have formed since) with 100 grit aluminum oxide.
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali3.jpg">
Then blow with compressed air to remove any aluminum oxide left on the caliper.
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali2.jpg">
This is a pic of the modified oven I used for the heating part.
<img src="http://i132.photobucket.com/albums/q33/x1rider/ex7.jpg">
So I tied the caliper to the grille which makes it easier to suspend in the oven and for the coating. I placed the caliper in the oven at 450F for 30 minutes to help open the pores and let any oil or gasses out.
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali4.jpg">
It is important that the part is at 450F, for that, I monitored the temperature of the caliper with an infrared thermometer.
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali5.jpg">
For the coating, I used Cerakote (red) and a touch up HVLP paint gun (0.8mm nozzle).
<a href="http://www.caswellplating.com/powder/ceramics.html">Cerakote></a>
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali6.jpg">
Then I hung the part, waited for it to cool down to about 150F.
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali7.jpg">
I applied the Cerakote (that was a real PITA because the caliper has a lot of grooves and corners).
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali8.jpg">
The next part was not in the instructions but I put it back into the oven for 1 hour at 450F for curing. I'm not sure it was a good idea, more on that later.
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali9.jpg">
Then I hung it again and allowed cooling down to 160-180F and shot it with silicone spray and wiped the excess off.
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali10.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/ex15.jpg">
Pictures of the finished product.
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali11.jpg">
<img src="http://i132.photobucket.com/albums/q33/x1rider/cali12.jpg">
After a few hours, the caliper seemed to be more of an orange than a bright red. I am not sure if this is due to putting it back in the oven after the application (the instructions said to air dry). When I get my hands on another caliper, I'll try to let it air dry and see if it makes a difference.
Let me know if there are any questions.
<center><img src="http://i132.photobucket.com/albums/q33/x1rider/apart2-1.jpg"></center><p>
I have to buy a rebuild kit to put it back together.
one set for dust and another one for paint.
A sandblasting cabinet would definitely reduce some health hazards.
Which would become disturbed whenever you moved boxes or stuff in the garage. I wonder if you could rig a fan shroud to pull the air/dust into a reducer that would fit up to some flexible ducting. That ducting could then go to the inlet of a shopvac with a hepa/silica proof filter.
