Do these speakers fit in our cars?
<center><img src="http://pictureposter.audiworld.com/47229/0f_1.jpg"></center><p><ul><li><a href="http://www.crutchfield.com/S-RKAOclvfbNC/cgi-bin/ProdView.asp?g=410&tab=detailed_info&i=500 SPR17LS">http://www.crutchfield.com/S-RKAOclvfbNC/cgi-bin/ProdView.asp?g=410&tab=detailed_info&i=500 SPR17LS</a</li></ul>
so that the Bose system can handle it? I'm talking direct replacement front/rear speakers.
you can reuse everything but power and ground from the factory wiring harness. just disconnect from the factory bose amp, and use wire taps to splice in (if you're concerned about being able to return to stock), or cut out the wires you need from the harness, and splice in new wires to lengthen as necessary
stairway2evan
09-03-2015 11:40 AM
ECS Tuning-Audi
08-31-2015 01:12 PM
Addison1987a6
08-30-2015 06:40 PM
