Does the 02' 1.8T use a PCV valve ?
I found it searching for "recirculation" which took me to the Mechanical recirculation valve, which was in the same diagram as the PCV.
meter the flow of blow--by gasses into the intake system when there is either a vacuum pressure or positive boost pressure in the intake manifold.
The suction jet pump, and the crankcase pressure regulating valve, provide for the removal of blow-by gasses from the crankcase, metering the flow into the intake manifold for all engine speeds and load ranges.
bballfreak
9
04-14-2019 06:59 PM
