Does the A4 have the same DV as the TT?
TT valves have been known to fail as well especially with over 1 bar chipped !
<center><img src="http://Fusion%20Racing"></center><p>
The new Evo DV is on sale here I believe...<ul><li><a href="http://www.fusionracing.net">http://www.fusionracing.net</a</li></ul>
This one is supposed to be good, especially if you are on a budget, not exact tt one...
<ul><li><a href="http://www.hoppenmotorsport.com/bypass.htm">http://www.hoppenmotorsport.com/bypass.htm</a</li></ul>
oh please...like the dealer will ever know you have a different bpv unless they go hunting for it
which they wouldn't unless they suspected it was broken.
Besides that, it's an OEM part...you won't have an issue with that.
and finally...they wouldn't even know the diffrence between the valves, 710N is IDENTICAL in appearance to stock.
Go with the Porsche Turbo (the "110" valve) part...
It looks exactly the same and, according to some tuners with Audisport ties, performs better than the available aftermarket and TT valves.
