Does anyone have a list of items to be checked at 40 K miles services
From AoA's website:
Engine Oil - Change the oil.
Engine Oil Filter - Replace the oil filter.
Engine - Check for leaks.
Cooling System - Check the coolant level. Add coolant if necessary.
Exhaust System - Check for damage and leaks.
Engine, On-board Diagnostic - Check diagnostic trouble code memory. Purge if necessary.
Doors - Lubricate door hinge mechanism.
Battery - Check electrolyte level. Add if necessary.
Windshield Wiper and Washer - Check fluid level. Add fluid if necessary.
Automatic Shift Lock (ASL) - Check operation, including park/neutral position switch (where applicable).
Manual Transmission - Check gearshift mechanism and clutch for proper interlock operation.
Tires and Spare Wheel - Check for wear and damage. Check the pressure.
Service Reminder Indicator Display - Reset the display.
Brake System - Check for damage and leaks. Check thickness of pads and brake fluid level.
Drive Shafts - Check the boots.
Road Test - Check braking, kick-down, steering, electrical, heating and ventilation systems, air conditioning, and power accessories.
Lights - Check the lights.
Front Axle - Check dust seals on ball joints and tie rod ends. Check the tie rods.
Automatic Transmission - Check for leaks.
Automatic Transmission Final Drive - Check oil level. Add if necessary.
Manual Transmission - Check for leaks.
Manual Transmission Final Drive - Check oil level. Add oil if necessary.
Continuously Variable Transmission (multitronic) - Change ATF.
Power Steering Fluid - Check fluid level. Add if necessary.
Dust and Pollen Filter - Replace filter.
Headlights - Inspect headlights. Adjust if necessary.
Sliding Roof - Clean guide rails and lubricate with grease spray.
Air Cleaner - Replace filter element.
Spark Plugs - Replace the plugs.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
21
09-11-2021 04:04 PM
CPLYONS
09-07-2015 07:19 PM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
