does anyone know of any 12V sources that only put out voltage when the ignition is on
From a Valentine 1 hardwire installation... <a href="https://forums.audiworld.com/a4gen2/msgs/58774.phtml">Old Post</a>
I think you can also tap directly into the power block located behind the driver's side knee bolster. There's a write-up for that somewhere too...
How's the Projekt going?
AudiWorld Expert
Since I don't have a headunit anymore I don't have a signal to reamote turn on the amp. Well, I figured that was an easy one. I'll just use the 12 Switch wire for the stereo...for some reason when I hook it up to the the remote wire for the amp it drops to 1 volt. But when I hook it up to constant it works fine.
