Does anyone know if the 996 calipers can work with 332mm rotors ?
you want to have some unswept area on the rotor...with custom brackets you can mate any caliper to any rotor pretty much. Oh, and also I had to file down the pins on the caliper to accept 30mm wide rotors. Stock 996 C2/4 front rotors are 318x28mm
Leaves about 0.5mm on either side of the rotor to clear the caliper "pins". The 996tt caliper has a much wider rotor opening but uses a different mounting bolt pattern than most Porsche calipers.
N'Syncro
33
02-16-2020 03:12 PM
Optimusglen
09-02-2015 07:24 AM
