does the pully, tensioner and water pump need to be replaced with the timing belt??
Old 05-26-2010, 06:04 PM
asn
asn's Avatar
Default does the pully, tensioner and water pump need to be replaced with the timing belt??
I am looking at buying a used 2006 A4 cab with 90,000 miles on it. The timing belt was replaced at 75,000 miles as a CPO, but the owner didn't replace anything else. Do these need to be replaced ASAP? If not, when should they be replaced?
It is a 3.0 V6 if that matters.
Other then that, the 5, 15, 25....75k services have been performed.
Old 05-27-2010, 11:01 AM
Audi for life 1987's Avatar
Thats up to you but its cheap insurance. One of those fail and the motor is toast!
Old 05-27-2010, 12:21 PM
Former Vendor
MikekiM@PureMS's Avatar
Absolutely.. All the timing components should be changed together.
Tensioner, relay rollers, belt, waterpump.
Old 05-27-2010, 12:47 PM
asn
asn's Avatar
So, the timing belt was changed at 75k, and the car now has close to 90k. Do we bit the bullet and do the rest now, or wait a while?
It is my understanding that you do the other things along with the timing belt, to save on labor in case any of those fail, but the timing belt is the most important thing to get swapped out.
Old 05-27-2010, 04:51 PM
Spinnetti's Avatar
Tough call. If you are going to pay somebody to do it, i'd wait and risk it.
Old 05-27-2010, 05:19 PM
turbo510's Avatar
A "timing belt failure" is often the result of something else failing first. A tensioner looses tension, or a idler pully, water pump, or even a camshaft seizes. So just changing the belt may not improve the risk of breakage.
Old 05-28-2010, 06:54 PM
initialA4's Avatar
if you are doing the timing belt, might as well do it all since its all in the same area!
JAB225
12-16-2004 05:40 AM
audiluver
03-11-2003 08:46 AM
SandrA S4
02-25-2003 05:19 PM
CEEZZ
12-11-2002 01:27 PM
sanfran_a8
08-23-2002 01:16 PM
Quick Reply: does the pully, tensioner and water pump need to be replaced with the timing belt??
