Doing rear brakes this weekend.
#22
it has a joint right above the clamping point so that you can turn the threaded bar and tighten it without the clamping point turning as well.
are there clamps that don't do that?
#23
but the piston is not that hard to rotate, just the pressure going through the threaded bar is enough to lock the joint and rotate the piston. At first I thought I would use the C-clamp to push the piston straight back but as soon as I started turning the threaded bar, I saw that the piston was rotating as well. ...at least it worked on mine and I had a few problems getting the right pads so I have taken the calipers off and pushed back the pistons at least 4 to 5 times with the C-clamp and never had a problem.
#25
If you don't trust the C-clamp, there is probably a way you can lock the jointed end (weld, bracket it, etc...) for a lot cheaper than $50.00. However, like I said, I did it quite a few times and the piston rotated every time.
Cmmartin23
26
08-23-2016 04:44 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
ajg617
09-06-2015 07:23 AM
