Doors not Locking - Comfort Control Module Location - in Floor or Under Dash?
I have door not locking issues and I am reading the module is under the dash and then some people say under the carpet. Can someone clear this up for me?
VAG COM tells me this, if anyone could find it in their heart to tell me what this mess means. I see low voltage to the unit.. Makes me think maybe wiring, not the actual module needs replacing? Thanks!
Address 46: Central Conv. Labels: 8E0-959-433-MAX.lbl
Control Module Part Number: 8E0 959 433 T
Component and/or Version: Komfortgerát T5B 0619
Software Coding: 11788
Work Shop Code: WSC 09401
Additional Info: 8E1959801 Tőrsteuer.FS BRM 4.22
Additional Info: 8E1959802E Tőrsteuer.BF BRM 4.22
Additional Info: 8E0959801A Tőrsteuer.HL BRM 4.10
Additional Info: 8E0959802A Tőrsteuer.HR BRM 4.10
VCID: 42854C2A4E2BBF08778
17 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
53-10 - Supply Voltage Too Low - Intermittent
01370 - Alarm triggered by Interior Monitoring
35-00 - -
01572 - Alarm triggered by Door Contact Switch; Passenger Side
35-00 - -
01574 - Alarm triggered by Door Contact Switch; Right Rear
35-00 - -
01573 - Alarm triggered by Door Contact Switch; Left Rear
35-00 - -
01811 - Supply Voltage for Door Controller; Drivers Side (J386)
37-00 - Faulty
01559 - Drivers Door
37-10 - Faulty - Intermittent
01331 - Door Control Module; Driver Side (J386)
01812 - Supply Voltage for Door Controller; Pass. Side (J387)
37-00 - Faulty
01560 - Passenger Door
01332 - Door Control Module; Passenger Side (J387)
01813 - Supply Voltage for Door Controller; Rear Left (J388)
37-00 - Faulty
01561 - Left Rear Door
01333 - Door Control Module; Rear Left (J388)
01814 - Supply Voltage for Door Controller; Rear Right (J389)
37-00 - Faulty
01562 - Right Rear Door
01334 - Door Control Module; Rear Right (J389)
17 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
37-00 - Faulty
37-00 - Faulty
37-00 - Faulty
37-00 - Faulty
17 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
37-00 - Faulty
37-00 - Faulty
37-00 - Faulty
37-00 - Faulty
17 Faults Found:
35-00 - -
35-00 - -
35-00 - -
35-00 - -
37-00 - Faulty
37-00 - Faulty
37-00 - Faulty
37-00 - Faulty
Would read through the other thread going on right now "fault codes please help" with similar problem and wasn't the CCM.
