DV Installation - Hose clamps required?
Bought a DV off ECSTuning, and information states "Hose clamps not included (34mm clamps needed)"... Are these clamps already there, holding the stock DV in place? Or do I need to purchase ?
Thanks for any info..
they are hard to get off, you'll probably end up cutting them. I used T-Bolt clamps for my DV, they hold like there's no tomorrow.
<img src="http://i132.photobucket.com/albums/q33/x1rider/h7.jpg">
You can get some here, amongst other places.<ul><li><a href="http://hightempsilicone.com/category/stainlessctclamps.tbolts/">http://hightempsilicone.com/category/stainlessctclamps.tbolts/</a</li></ul>
<img src="http://i132.photobucket.com/albums/q33/x1rider/DVclamps.jpg">
I used two 1" T-Bolt clamps and one small regular hose clamp for the vacuum line (some people even use zip ties instead for this one).
Your setup is probably not going to look exactly like mine because I removed a few parts in that area.
I was changing all my FMIC clamps to T-bolts so I figured why not while I'm working in the area. I was getting a little fed up with stripping regular hose clamps while tightening them so I decided to go with the T-bolt, no way I'm ever going to strip these, the tubing will collapse first!
