Engine tone sounds like a whale when gas pedal is initially depressed and car moves from standstill.
anyone experience this? any ideas? is there a module i can test and measure with vag to diagnose and pinpoint the problem? something like "bluhh" and then the boost kicks in... hmmm! >:^|a
I lifted this from Hoppen's website promoting a simple Bosch bypass valve. Does this describe your symptom?
From Hoppen:
"As stated in Audi's technical bulletin dated Dec. 8, 2000 the bypass valves should be replaced should the following occur: "Groaning or howling noise from engine compartment when accelerating during partial load between 2500-3000 RPM," or " Rattling noise when decelerating between 2000-3000 RPM," which "may be caused by the internal diaphragm of the charge pressure bypass valve producing pulsating noises."
From Hoppen:
my TB o-clamp came off once and it sounded similar. kinda like a "bluhhh" when i launch from standstill.
Will it do it? What I mean is, if you place the car in neatral and rev it can you get it to make the same noise? If you can, then you can have someone rev it while you walk around the car to make sure. Good luck.
wantfryswiddat
09-21-2015 05:55 AM
arjun90
10
09-02-2015 05:35 AM
