ESC Clutch Driveline Resonance
A few months ago I installed an ECS stage one clutch with the steel flywheel. I don't get any gear chatter which is great. The issue is that I get some serous driveline related vibrations if I give the car more than 20% throttle below 2k rpm. At 2k rpm and above it completely goes away. This is not the result of me stepping on it and cogging the engine down low. Even a little throttle at 1800 rpm causes a serious vibration. Everyone who drives my car is alarmed by it.
Does anyone else have this problem? I have never read about it before but then again most people seem to have the aluminum flywheel. I am guessing that this is just a result of removing the dual mass flywheel and I have to live with it but I wanted to make sure there was nothing that I can do to fix it.
Thanks in advance.
2004 A4 1.8T Quattro Ultrasport
Stage 1+
Thanks in advance.
Stage 1+
You went from a dual-mass flywheel....
which was designed to dampen out those vibrations, to a single mass flywheel. What your experiencing is normal. I had the same issue when I had the Spec single mass light-weight flywheel.
ECS Tuning-Audi
S4 (B8 Platform) Discussion
07-26-2018 02:02 PM
ECS Tuning-Audi
02-04-2016 08:36 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-24-2015 12:06 PM
