ESE Hubcentric Wheel Spacers now available and IN STOCK!
Old 03-02-2006, 06:59 AM
New Member
Euro Styles East's Avatar
Default ESE Hubcentric Wheel Spacers now available and IN STOCK!
<a href="http://www.eurostyleseast.com" target="_blank"><img src="http://www.eurostyleseast.com/tuning/images/forumsjpg/ese-footer.gif" border="0"></a>
<a href="http://www.eurostyleseast.com/tuning/item.asp?IC=ESE-SPACER-MID" target="_blank"><img src="http://www.eurostyleseast.com/mm/images/ese/spacer/allspacerspic2.jpg" border="0"></a><a href="http://www.eurostyleseast.com/tuning/item.asp?IC=ESE-SPACER-MID" target="_blank"><img src="http://www.eurostyleseast.com/mm/images/ese/spacer/allspacerspic1.jpg" border="0"></a>
<b>Go Wide!</b>
Whether you're adding style to your car, or if you're in need an extra racing edge by creating a larger wheelbase, then ESE Hubcentric Wheel Spacers are for you.
CNC Machined with the utmost precision using aircraft grade aluminum, ESE Wheel Spacers are lightweight yet durable due to their hard black anodized finish.
All ESE Hubcentric Wheel Spacers require longer lug bolts.
<b>5mm spacers (Pair) = $55.00</b>
<a href="http://www.eurostyleseast.com/tuning/item.asp?IC=ESE-SPACER-MID" target="_blank"><img src="http://www.eurostyleseast.com/mm/images/ese/spacer/5mmspacerpic1.jpg" border="0"></a>
<b>10mm spacers (Pair) = $70.00</b>
<a href="http://www.eurostyleseast.com/tuning/item.asp?IC=ESE-SPACER-MID" target="_blank"><img src="http://www.eurostyleseast.com/mm/images/ese/spacer/10mmspacerpic1.jpg" border="0"></a>
<b>15mm spacers (Pair) = $80.00</b>
<a href="http://www.eurostyleseast.com/tuning/item.asp?IC=ESE-SPACER-MID" target="_blank"><img src="http://www.eurostyleseast.com/mm/images/ese/spacer/15mmspacerpic1.jpg" border="0"></a>
<b>20mm spacers (Pair) = $105.00</b>
<a href="http://www.eurostyleseast.com/tuning/item.asp?IC=ESE-SPACER-MID" target="_blank"><img src="http://www.eurostyleseast.com/mm/images/ese/spacer/20mmspacerpic1.jpg" border="0"></a>
<b>Remember, all orders over $99 receive FREE Ground Shipping!</b>
Old 03-02-2006, 07:23 AM
Senior Member
shadyraven's Avatar
Good price for the spacers, how much for the bolts?
Old 03-02-2006, 07:39 AM
Senior Member
a4tis™[Bye Turbo]'s Avatar
how do i know what size to use if i want the wheel flush with the fender?
Old 03-02-2006, 08:11 AM
Senior Member
shadyraven's Avatar
For flush to fender go with 15mm.
Old 03-02-2006, 08:19 AM
Senior Member
thanks!
Old 03-02-2006, 08:55 AM
Avantéix's Avatar
it will all depend on your current wheel offset and width...
Old 03-02-2006, 09:12 AM
Senior Member
shadyraven's Avatar
I should add... 15mm is best if you're using the stock sport rim.
Old 03-02-2006, 09:23 AM
Senior Member
good to know - i plan on swapping my OEM 17" sports for 18"s this spring
Old 03-02-2006, 01:57 PM
New Member
Default Re: Good price for the spacers, how much for the bolts?
We offer H&amp;R extended lug bolts for $29.50 for a set of 10. They are add-on items to our spacers or available separately on our website.
Old 03-03-2006, 04:12 PM
QuattroRocket's Avatar
How big a spacer can you run before you need new bolts ?
Quick Reply: ESE Hubcentric Wheel Spacers now available and IN STOCK!
