ESP light came on.
Was sitting in trafick yesterday on the way home, and the ESP light comes on. Had the same thing happen to me on the way to work after about 3 mins of driving. Any ideas why? Got the 03 A4 3.0
<center><img src="http://www.ross-tech.com/UwesStoreConcept/key-com-med.jpg"></center><p>its all guess-work...<ul><li><a href="http://www.ross-tech.com">http://www.ross-tech.com</a</li></ul>
sign of a soon to be dead battery. Replaced battery and magically no more ESP light. You have an 03 with likely the factory battery still. Either way its time for a new battery and worth a try. New battery from VW dealer was $103, could not find the $45 Walmart versions referred to when I STF. The amps were right, but the size was too small. You will also need very long hex key, 6 mm. Sears sells a t-handle set that is 8" long, 6" is too short.
I was playing with my scanner the other day on a 2011 Audi a 8 quattro. I ended up triggering something that set off a bunch of faults like steering wheel, esp, acc, sport differential, etc. Has anyone done this and knows the fix? I tried resetting the steering angle and clearing codes to no avail........heeeeeellllppppp! Thanks. I'm wondering if disconnecting the batt will do the trick.
hellonwheels33
32
04-16-2023 07:32 AM
hardipk5
17
11-24-2015 03:42 AM
