Estimated time for installing a Thermal Exhaust (rear section only) ??with ramps or jack stands
If you are only installing from the rear flanged sections onward, there will be cutting and welding to do. If you already installed the proper front section and are just bolting up the rear section to it than it should only take about 30 minutes. If the rear tips need adjustment, just unscrew the center ajustment bracket and move the pipes inward or outward as desired, then retighten.
With the stock downpipe, your going to have to adapt the smaller pipe diameter to the larger. This can be done with a small section of pipe reduced at one end than welded or clamped to both your stock downpipe and the Thermal system. If you get this piece made for you, than you have eliminated half the install time of the system. The downpipe is the tricky part to install. Best way to get the old one off is to burn the old bolts off. You don't have to worry about this so it shouldn't take you but 35-45 minutes. Id try and get a custom downpipe made, however if you cant get one from Thermal. Talk to oneeight for all kinds of custom Audi eshaust pipes. Cheers! Mike
that seems kinda odd...i have an auto and it looks as though i can just taker off the exhaust pipe clamp thats towards the mid/fron of the car and slide the thermal in.
ECS Tuning-Audi
A4 (B8 Platform) Discussion
22
05-11-2024 04:38 PM
N'Syncro
33
02-16-2020 03:12 PM
Audi A4 2002 S4 6spd 98k
rsixxer23
01-06-2016 03:25 AM
giuseppepat
09-02-2015 02:47 AM
ECS Tuning-Audi
09-01-2015 08:27 AM
