First VAG Scan..help needed badly
had my first VAG scan today and here are the codes..don't know what to make of them, I'm sure you guys could help
VAG-COM Version: Release 704.1
Data version: 20071016
Friday,11,April,2008,12:19:48:37937
Chassis Type: 8E - Audi A4 B6/B7
Scan: 01 02 03 08 09 0F 11 15 16 17 18 36 37 45 46 55 56 57 65 67
69 75 76 77
VIN: WAUZZZ8E03A031004 Mileage: 65850km/40917miles
Address 01: Engine Labels: None
Part No SW: 8E0 909 557 L HW: 8E0 909 057 A
Component: 2.0L R4/5VS 0001
Coding: 0004581
Shop #: WSC 63351
13 Faults Found:
16955 - Brake Switch (F): Implausible Signal
P0571 - 008 - Implausible Signal - Intermittent
17648 - Fuel Injector for Cylinder 4 (N33): Open Circuit
P1240 - 004 - No Signal/Communication - Intermittent
16684 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - Upper Limit Exceeded - Intermittent
16688 - Cylinder 4: Misfire Detected
P0304 - 001 - Upper Limit Exceeded - Intermittent
16946 - System Voltage: Too Low
P0562 - 002 - Lower Limit Exceeded - Intermittent
17887 - Brake Boost Vacuum System: Mechanical Failure
P1479 - 008 - Implausible Signal - Intermittent
18017 - Crash Shut-Down Activated
P1609 - 001 - Upper Limit Exceeded
18010 - Power Supply Terminal 30: Voltage too Low
P1602 - 002 - Lower Limit Exceeded - Intermittent
17645 - Fuel Injector for Cylinder 1 (N30): Open Circuit
P1237 - 004 - No Signal/Communication - Intermittent
17646 - Fuel Injector for Cylinder 2 (N31): Open Circuit
P1238 - 004 - No Signal/Communication - Intermittent
17700 - Map Controlled Engine Cooling Thermostat (F265): Open Circuit
P1292 - 004 - No Signal/Communication
18339 - Coolant Fan Control Module (J293): Malfunction
P1931 - 004 - No Signal/Communication - Intermittent
17544 - Fuel Trim: Bank 1 (Add): System too Lean
P1136 - 001 - Upper Limit Exceeded
Readiness: 0000 0000
Address 02: Auto Trans Labels: None
Part No: 01J 927 156 CR
Component: V30 01J 2.0l 5V RdW 2011
Coding: 00001
Shop #: WSC 63351
No fault code found.
Address 03: ABS Brakes Labels: 8E0-614-517.LBL
Part No: 8E0 614 517
Component: ABS/ESP front 1726
Coding: 04279
Shop #: WSC 06435
1 Fault Found:
01826 - Sensor for Steering Angle (G85); Supply Voltage Terminal 30
35-10 - - - Intermittent
Address 08: Auto HVAC Labels: 8E0-820-043.LBL
Part No: 8E0 820 043 K
Component: A4 Klimaautomat 1015
Coding: 00000
Shop #: WSC 63351
4 Faults Found:
01274 - Air Flow Flap Positioning Motor (V71)
41-10 - Blocked or No Voltage - Intermittent
00604 - Potentiometer Positioning Motor for Air Flow Flap (G113)
30-10 - Open or Short to Plus - Intermittent
00735 - Potentiometer in Positioning Motor for Air recirculation Flap (G143)
30-00 - Open or Short to Plus
00819 - High Pressure Sensor (G65)
Address 09: Cent. Elect. Labels: 8E0-907-279-8E2.LBL
Part No: 8E0 907 279 E
Component: int. Lastmodul RDW 0305
Coding: 00001
Shop #: WSC 63351
5 Faults Found:
01498 - Bulb for Parking Lamps; Right (M3)
57-00 - Electric Circuit Failure
00979 - Lamp for Low Beam; Right (M31)
01499 - Bulb for High-Beams; Right (M32)
01493 - Bulb for Blinkers; Front Left (M5)
01497 - Bulb for Blinkers; Front Right (M7)
Address 15: Airbags Labels: 8E0-959-655-84.LBL
Part No: 8E0 959 655
Component: Airbag 8.4E 5001
Coding: 0010602
Shop #: WSC 63351
Address 16: Steering wheel Labels: 8E0-953-549.LBL
Part No: 8E0 953 549 L
Component: Lenksáulenmodul 0308
Coding: 02111
Shop #: WSC 63351
1 Fault Found:
01304 - Radio
49-10 - No Communications - Intermittent
Address 17: Instruments Labels: 8E0-920-9xx-8E2.LBL
Part No: 8E0 920 900 H
Component: KOMBI+WEGFAHRS. RB4 D27
Coding: 00100
Shop #: WSC 00001
WAUZZZ8E03A031004 AUZ6Z0B0121180
1 Fault Found:
00668 - Supply Voltage Terminal 30
53-10 - Supply Voltage Too Low - Intermittent
Address 46: Central Conv. Labels: 8E0-959-433-MAX.LBL
Part No: 8E0 959 433 AH
Component: Komfortgerát T1B 0619
Coding: 06730
Shop #: WSC 63351
Part No: 8E1959801B
Component: Tõrsteuer.FS BRM 0002
Part No: 8E1959802B
Component: Tõrsteuer.BF BRM 0002
Part No: 8E0959801A
Component: Tõrsteuer.HL BRM 0002
Part No: 8E0959802A
Component: Tõrsteuer.HR BRM 0002
9 Faults Found:
01330 - Central Control Module for Central Convenience (J393)
01134 - Alarm Horn (H12)
01370 - Alarm triggered by Interior Monitoring
35-00 - -
00962 - Alarm via. Tilt Sensor
35-00 - -
01368 - Alarm triggered by Luggage Compartment Switch
35-00 - -
01331 - Door Control Module; Driver Side (J386)
01332 - Door Control Module; Passenger Side (J387)
01333 - Door Control Module; Rear Left (J388)
01334 - Door Control Module; Rear Right (J398)
Address 56: Radio Labels: None
Part No: 8E0 035 195 C
Component: symphony II NP2 0151
Coding: 00005
Shop #: WSC 00001
End ------------------------------------------------------------------------------------------------
69 75 76 77
Coding: 0004581
Shop #: WSC 63351
13 Faults Found:
Coding: 00001
Shop #: WSC 63351
Coding: 04279
Shop #: WSC 06435
1 Fault Found:
Coding: 00000
Shop #: WSC 63351
4 Faults Found:
Coding: 00001
Shop #: WSC 63351
5 Faults Found:
Coding: 0010602
Shop #: WSC 63351
Coding: 02111
Shop #: WSC 63351
1 Fault Found:
01304 - Radio
Coding: 00100
Shop #: WSC 00001
1 Fault Found:
Coding: 06730
Shop #: WSC 63351
Part No: 8E1959801B
Part No: 8E1959802B
Part No: 8E0959801A
Part No: 8E0959802A
9 Faults Found:
35-00 - -
35-00 - -
35-00 - -
Coding: 00005
Shop #: WSC 00001
Logging the voltage when car is on, off, might not be a bad idea first though. Possible the battery is OK and the alternator or voltage regulation is bad.
i personally wouldnt be suprised if that was the cause of the majority of these faults...a couple may return, but most should go away.
Book mark this site, put it in your "favorites"...<ul><li><a href="http://wiki.ross-tech.com/index.php/Category:Fault_Codes">http://wiki.ross-tech.com/index.php/Category:Fault_Codes</a</li></ul>
wjhpilot
S4 (B8 Platform) Discussion
09-04-2015 01:43 PM
ECS Tuning-Audi
09-03-2015 12:45 PM
mkirkpatrick
Wheels & Tires Discussion
09-03-2015 08:31 AM
