Forge007 DV Install
I've tried searching and haven't come up with anything detailed. Can someone please post up a link? I don't want to jump into this unless I've got some good directions. Thanks.
either ramp or jackstands.
remove belly pan, there are a ton of screws on the bottom. there are also 2 screws in each wheel well. once all the screws are out the belly pan will slide out if you pull towards the back of the car
find the DV, its near the front of the car, take a dremel and CAREFULLY cut the stock clamps, make sure to not cut into the hoses
remove stock dv, replace with new DV. connect hoses and put NEW clamps on the return and the ic hoses 1" iirc. then connect vaccuum nipple and ziptie that down.
replace belly pan and you're good to go.
new one goes in same way old one comes out. i have mine inverted so you basically cant even screw up the direction. also, you will need some hose clamps various sizes.
xkahn
02-08-2018 10:43 AM
AlllRoad
09-15-2015 12:51 PM
ECS Tuning-Audi
Audi A3 / S3 / RS 3
09-11-2015 11:56 AM
ECS Tuning-Audi
A4 (B7 Platform) Discussion
09-01-2015 09:16 AM
