Forgive me if I'm wrong, but i thought quattro was only active while accelerating?
have the clutch in, i guess technically you could say it's not active, but no more so than a rear wheel drive car with the clutch in
it is "always" working, but YES - the more you accelerate it will work. Quattro has to send power to wheels that are slipping (its how it works). If you are not on the gas, then the car has no power to send to the gripping wheels.
The traction control works for you when you are braking.
See the pattern?
See the pattern?
The Torsen (Quattro) system is pernament, full-time AWD...you're always driving 4 wheels with the engine. I suppose if you are in neutral, then no power is sent to the wheels, then there is no torque for the system to sense.<ul><li><a href="http://autozine.kyul.net/technical_school/traction/tech_traction_4wd_2.htm#Torsen">Click here to learn more about Torsen, ATTESA and Haldex</a></li></ul>
