Gas Gauge Issue
My 2002 A4 3.0 gas gauge showed empty, and the indicator light was flashing. I filled the tank and when I drove away, for the first time since I have owned the car, the indicator light stayed on and the needle is still at empty. Help!
I have no idea why the battery died but after recharging the gage moved up a bit and then over the next several days it recovered completely.
I would guess that there is a capacitor in the sender that recovers very slowly. At least that is my guess.
Same thing happened to me. I searched the forum and found someone with the same problem.
The solution was to disconnect your battery for app. 30 seconds and then reconnect it.
The gauge should then read normally, as well as the trip computer.
is when it happened to me a couple of times, i refueled and still showed empty, warmed the car up and still empty. i either found the secret to fixing this issue or it is indeed a fuel sender starting to go out. i watch my milage until it gets to around less that a half tank or around a quarter (guessing obviously) and then i fill it up and everytime it has worked again, sometimes it will register not full but if you drive around a bit it slowly makes its way back to full. im confused on what it could be though, it seems like a electrical problem cause its only happened when the battery dies like you mentioned. hopefully it works for you if you still have this problem. say no to cold weather!!!
which average out when the car is turning , etc..
They gum-up over time resulting is erratic readings.
A couple of bottles of Chevron Techron cleaner will
usually clear it up.
Hav'nt seen it yet on my 05 3.0Q Cab but the ol TT had this problem a lot.
Total solution was a new sender.
My 2 cents.
My 2 cents.
carl viking
40
07-12-2024 02:45 PM
ECS Tuning-Audi
09-08-2015 01:08 PM
ECS Tuning-Audi
09-08-2015 11:47 AM
ECS Tuning-Audi
09-08-2015 10:42 AM
S4intheOC
09-08-2015 12:12 AM
