Getting this faint 'wheeeeee' sound from the rear driver side wheel area
Just finished a track session at Bremerton and I hear this sound.
It's not a air leak and some times the sound pulsates and other times it is continuous but it doesn't happen all the time.
It only recently started to happen and the first suggestion is that it might be the fuel pump.
Any other ideas as to what it may be?
EDIT: I forgot to mention I only hear the sound when the car is parked and I walked past the rear driver side wheel area. As I said before it is intermittent and starting the car does not make the sound go away. I cannot hear the sound from the inside when driving.
it may be something as simple as a hubcentric ring put on backwards (if you have them). i know it sounds stupid, but it's happened to me and made me wonder WTF was that embarrassing sound...it was a pitched, squeak, squeak, squeak noise that got louder as i accelerated. turned out that my hubcentric ring was put on backwards and wiggled around as it moved.
in the driver's side rear wheel well. I don't have a Bentley here at work but somebody else can check it for you. Maybe its just a loose vacuum line.
Fuel pump does not make sounds unless its running.
when the coilovers were being installed.
That might be what is making the sound but the question is how do you test it?
There's a filter element on the leak detection pump which is part of the EVAP system. The LDP isn't really a pump per se, just a solenoid valve with a sensor. It wouldn't be making the noise.
Can you tell if it's a motor running type of sound, or an electronic beeping type of sound? Next time it happens, hit the panic button on your remote and see if it changes when the alarm beep goes off.
Check your trunk too, maybe you have some gizmo in your trunk, such as a cell phone, going off?
the sound is a very level 'weeee' tone that either stutters or is a continuous tone.
It's not a beep at all. It is a tone and it could be a vacuum leak but the sound is not a hiss.
The weird thing is that the sound do not happen all the time.
Nothing is in the car that would make that sound since I had to empty it out fro the track event.
