GIAC FX users with NGK BKR7E plugs, what gap are you running? ...
Old 10-14-2006, 12:52 PM
FoKai's Avatar
Default GIAC FX users with NGK BKR7E plugs, what gap are you running? ...
I just bought BKR7E plugs and will replace my BKR6Es. I know it sounds kinda trivial, but are you gapped at .028 or .032?
I understand regap .004 for every 50 hp. How about meeting in the middle and gapping at .030?
Old 10-14-2006, 01:50 PM
x1rider's Avatar
Default Re: GIAC FX users with NGK BKR7E plugs, what gap are you running? ...
I heard/read 0.032 to 0.028 so I went 0.030 (right in the middle) myself.
From what I can understand, if you get misfires from the increased boost blowing off the spark, you can go a bit tighter on the gap.
Old 10-14-2006, 02:23 PM
x1rider's Avatar
Actually, try paging Diagnosticator1, if anyone knows, it's him.
Old 10-14-2006, 02:29 PM
FoKai's Avatar
Default Just did a Google search...
and an article said anywhere between .028-.034 is fine; however, the million dollar question is, what is the *optimal* gap?
most of the other articles i found were gapped at .030. these articles, however, were for the b5 s4.
Old 10-14-2006, 03:07 PM
x1rider's Avatar
Default Re: Just did a Google search...
Optimal probably depends on a million factors!!! I can tell you that with 0.030 didn't give me any misfires yet (remember though, I still have the old FX version, if that makes a difference)
Old 10-14-2006, 03:39 PM
FoKai's Avatar
Default AW search result... good info:
<ul><li><a href="https://forums.audiworld.com/tt/msgs/1299027.phtml">readme</a></li></ul>
Old 10-14-2006, 03:41 PM
x1rider's Avatar
Great reference to keep handy! Thanks!!!
Old 10-14-2006, 05:08 PM
Murphy'sSidekic's Avatar
Default I run at .032". The OEM gap is .028" - this is because...
...as time goes on, and the original plugs start to see high milage, the gap expands. So essentially, the OEM spec is to under-gap the plugs to make the plugs last longer.
Old 10-14-2006, 05:44 PM
New Member
euroshowoff's Avatar
I run bosch FR5 DTCs no gapping required...runs like a champ
Old 10-14-2006, 08:07 PM
MC Hammered's Avatar
I gapped mine at 0.030" and it works great.
Quick Reply: GIAC FX users with NGK BKR7E plugs, what gap are you running? ...
