on-going issue - dash noise
I have had an on-going issue with a mechanical noise behind the HVAC/headunit - near the glove box.
Service diagnosed it as HVAC not working correctly - flaps aren't opening and closing properly. They've replaced the HVAC computer and the flap motor, which controls airflow. The noise has recently returned. The dealer has a call into AoA at this point.
The sound is similar to CDs shuffling - but it isn't the headunit. The sound is present after starting the car - regardless of the radio or HVAC being on or off. It also continues temporarily after the car is turned off - any ideas?
sure but that's typically the only door that moves when you first start the car and after you've shut down the car.
Found a few others with similar problems:
<a href="https://forums.audiworld.com/a4gen2/msgs/623394.phtml">https://forums.audiworld.com/a4gen2/msgs/623394.phtml</a>
p.s. reflashed today - no more CEL
and we actually have a motor that moves the flaps in the HVAC. They're usually driven off vacum from the vacum booster by the master cylinder...interesting.
ZPA117
A4 (B8 Platform) Discussion
09-08-2015 11:55 AM
stormchaser1967
09-02-2015 09:26 AM
stormchaser1967
09-02-2015 09:02 AM
