Got a set of S4 Bi-Xenon Ecodes, but need balast and bulbs
i got a set of S4 Bi-xenon's.
but i still need some balast and bulbs.
any suggestions which to get ?
i am retrofitting it from Halogen to Bi-Xenon.
i cant use other bulbs if i get OEM balast they told me.
So is any balast and bulb good ? or do i need a certain brand or type ?
on eBay. You need the "5GL", "thin" style ballast. See the link for a detailed explanation. In addition, you will need to get the ballast>lamp cables.<ul><li><a href="http://www.lltek.com/PRS_bin/PRS_69_A48E_Ballasts_claire.htm">Ballast description:</a></li></ul>
You can find them on eBay seaching under 'valeo ballast*'
You can find them in the AZ classifieds or you can find a set on hidplanet.com
I sourced my 5400k D1S, ballasts and cables from that site and the transactions were painless.
The bulbs you can source from suvlights.com.
The ballasts and cables (the thick metal one which connects the D1S bulb to ballast) you can source from eBay or on the AW/AZ classifieds
The 6000K Phillips and the 5400K Osram D1S lamps have lower light output rated at ~2800 lumens compared to the 4100K Osram and the 4300K Phillips, rated at ~3200 lumens.
See the link for more info.<ul><li><a href="http://faqlight.carpassion.info/headlight-menu1.htm">HID lighting info:</a></li></ul>
