GT2X w/ Unitronics - boost issues
Vagged the car and had no codes - Also boost leak tested and held 20psi
*Symptoms* Car is very sluggish , boost doesn't shoot up , has a ton of lag...
NOTE: I'm only getting a max MAF reading of ~172 g/s near redline and the readings are VERY low up until ~4300 rpms - Same goes for the boost, I only have like 3-6 psi at 3300 rpms. The GT2X should have 20psi at 3300 rpms. Any ideas? Bad MAF ?
Check out my logs
001 002 115
[url]Http://www.foundationsupplements.com...01 002 115.CSV[url]
002 031 115
[url]Http://www.foundationsupplements.com...02 031 115.CSV[url]
MODS:
ATP GT2X (oil/water cooled) Turbo // Genesis 415cc injectors // 3" MAF Housing // MBC // VMR Test Pipe // VMR Onyx Black 19" RS-4s // Custom TIP w/ K&N // Unitronics Tune // N249 Bypass // Short Throw w/ JHM bushings + Linkage
Check out my logs
001 002 115
002 031 115
MODS:
I wonder if you shouldn't pull the TIP from the compressor inlet AND disconnect the actuator vacuum line. If you can't be making boost before 3000 then, well, I'd say there's something wrong with the turbo.
I checked the compressor wheel and it spins freely and doesn't have play...
It should be shut, I adjusted it over a month ago - I made sure that the rod was as far forward (closed) as it can be. Then I adjusted the nut. I also pressurized it while watching the rod move and ensured that it took 10-12psi of pressure to make it start to open.
kkii9
03-30-2006 02:51 PM
leosphere
08-18-2005 01:48 PM
back2black
10-30-2004 01:26 PM
Tongpo~Dr. Evil
Performance and Tuning
34
10-29-2003 11:49 AM
