GTRS sudden crazy running at part throttle..
Ideas?
Been fine for 70k miles or so, now throwing these codes and boost goes randomly crazy between 10inhg and 10psi or so, pretty much randomly.. works fine at idle and full boost.. I doubt all these things failed at once, but dunno Could the first one cause the 2nd two?
16395 - Bank 1: Camshaft A (Intake)
P0011 - 002 - Retard Setpoint not Reached (Over-Advanced) - Intermittent
16622 - Manifold Pressure / Boost Sensor (G31)
P0238 - 001 - Signal too High - MIL ON
16490 - Manifold / Barometric Pressure Sensor (G71) / (F96)
P0106 - 008 - Implausible Signal - MIL ON
Clear codes and start the car letting it run for maybe 30 seconds and see if they all come back. I suspect the timing one is sympathetic to the real problem, which means it's the signal from one of the sensors or the sensor(s) themselves. I have no idea where those are, but if someone knows and can post, I would start by tracing hte wiring, checking for corrosion, lose connection etc.
E30drift
17
05-30-2015 11:32 PM
MeehowTT
12
02-17-2006 09:17 AM
Kapoosh1
12
10-16-2005 06:24 PM
NYLawyer
06-02-2002 03:41 PM
