H&R vs. H-Sport Sway Bars
#11
Richard,
Sport Suspension
Stock Fr 31mm tubular
Stock Rr 18mm
HSport A4
Fr 35mm tubular
Rr 22mm tubular
HSport S4
Fr 35mm tubular
Rr 24mm tubular
S4 kit will fit A4 cars, w/o modification. No reinforcement modification required. We can not guarantee that the rear subframe will not crack at the welds but we have done extensive testing with this product, it's been on the market for 18 months and keep in mind that the S4 comes from the factory with a slid, 20mm rear bar. That is pretty stout. In fact, this is the same diameter rear that comes from the factory on the RS6! Compare the vehicle weights between an S4 and an RS6 and there is quite a difference. We feel we have thoroughly tested the strength of the rear of both the A4 and S4. Finally, we offer the bars as sets only because there is so much roll up front and we designed the front to work with the rear so by adding a front bar no understeer is accumulated, plus, the increase in front bite at turn in is very apparent. Hope this helps.
Mark Hotchkis
HSport
12035 Burke Street
Suite 11
Santa Fe Springs, CA 90670
562.907.7757 ext227
Sport Suspension
Stock Rr 18mm
HSport A4
Fr 35mm tubular
Rr 22mm tubular
HSport S4
Fr 35mm tubular
Rr 24mm tubular
Mark Hotchkis
HSport
12035 Burke Street
Suite 11
562.907.7757 ext227
#12
Just curious when he mentioned strength of rear of A4 and S4 do you know if the A4 and S4 are the same or is the S4 beefed up more at the factory?
Have you heard any info on this issue.
#13
in suspension is the bars, shocks/springs.
I plan to ask my Audi service tech next time to see what he knows.. which may be little.
bballfreak
9
04-14-2019 06:59 PM
Audi Other 6 speed 2003 Audi RS6
alpinab7
10-07-2015 10:13 PM
Monsoonenough
S4 (B8 Platform) Discussion
10-03-2015 02:59 PM
