having a humming noise comming from a fuel filter I think.
Just recently i started hearing this anyoing humming noise it would come and go away every few mins. I looked under the car on passenger side right by where the fuel tank is and noticed what i think is the fuel fillter where the sound came from... Im just wondering is this a fuel filter or am i wrong. its right under the fuel tank pasender side in the back. And why is it making the humming noise any one ran accros this problem?
The filter has no moving parts, but the pump does which is lcoated basically just above the filter. However, the filter being dirty could cause the filter to work harder and make the noise you are talking about. My recommendation is get the filter replaced or DIY. Connectors are a little tricky, but other than that it is very straight forward.
http://www.audizine.com/forum/showth...uel+filter+diy
We have fuel filters available below for your DIY.
Click HERE to order or for more information.
![](http://c1552172.cdn.cloudfiles.rackspacecloud.com/89525_x600.jpg)
Let me know if you need help figuring out which to order since there is a VIN split.
Jason
Jason
That is exactly right. Our fuel pumps are somewhat fragile to begin with. Having it struggle to push fuel through a restricted filter will definitely shorten its life. I may just pre-emptively replace mine over the summer when I've got a little extra time.
The cat is under the hood. I suspect you are talking about the muffler / resonator near the rear passenger wheel. Anyway, that is most likely fuel pump whining. Change your filter and run for a while to see if it goes away. Link to a DIY for the filter are below.
