Headlight 2003 Audi A4
they're the more expensive ones. The D2S bulbs have a round base. You can't use those. The cheapest place I found was on Amazon but there's someone on these forums that sells them pretty cheap I've heard. Phillips are recommended. I went with some no name brand though.<ul><li><a href="http://www.amazon.com/PAIR-Replacement-Xenon-Bulb-6000k/dp/B0012ZGHRC/ref=sr_1_1?ie=UTF8&s=automotive&qid=120913 6711&sr=8-1">D1S @ Amazon</a></li></ul>
that loosen the headlight assembly. You have to loosen 3 per light (I think) and you don't totally unscrew them, just loosen them. Then the light will slide right out. Disconnect the wires and pull the bulbs out. They're held in with a metal clip. It's pretty easy. It's just getting to and seeing the screws that could be a pain the first time.
atikovi
02-21-2016 04:24 PM
mrogers58
08-31-2015 07:46 PM
sydneyman
08-27-2015 09:23 AM
sydneyman
08-27-2015 09:21 AM
